POE Wireless access point IP67 - Spec me up
1 Jan 2019
Hello,
I would your help to spec me a POE Wireless access point as my knowledge is lacking in these areas.
At the moment I have an Ethernet cable to my loft from my router going to a NONE POE switch witch in turn distributes out to Sonos amps.
What i would like to do is install a POE switch in my loft then run a Cat6 cable to the rear of my house, then mount a POE Wireless access point on the outside to service my medium sized garden.
It needs to be seamless so no logging into another network when walking outside to garden and then reentering the house.
If you have any recommendations on POE switch? I was thinking this one : NetGear 16 port / POE / 183 watts / Gigabit Ethernet un-managed switch Model number: GS116PP
Ensure your poe switch matches the spec of your poe device, generally I like the old 2.4Ghz nanostation m2's for directional wifi, but you could use something like a bullet with an omni, it depends where you want to mount it and the specific layout/coverage requirement.
