Point of View 9800GTX : Intro /Review
I dont understand why they test crysis at high res when its so clear that the card hasn't the grunt to run the game at high settings. whats wrong with testing with playable( realistic ) settings instead of quoting unplayable frame rates and giving a % of the speed differance last time i checked 50% of **** all is errm...still **** all!.
Crysis
1680x1050- 0X AA/AF @18 fps
1680x1050- 4X AA/16X AF @12 fps
1920x1200- 0X AA/AF @14 fps
Crysis
They're not exactly unrealistic res's though, are they? Most people game at 168x1050 i reckon and quite a lot at 1900x1200...
Because they want to try see what card can get the extra FPS out it, most play at 1600's or 1920's today.
The newer GPU's will try show there full potential at higher RES's and may not differ much at 1280's, some models only pull ahead of their siblings at 1600's or 1900's. :)
I see your point though.
Roll on more patches lol.
Most it out performs the ultra is 4% and most it is outperformed is by 58% by the ultra....
You sort of missed my point :) and that is playable frame rate, res then eye candy. So if say 1440x1050 = playable frame rate you can then give a fair represention of the differential between the cards in the group test.
I have a 24" dell 1920x1200 but to play a game at that res then it has to run at a playable frame rate (33fps) or it's unrealistic.
I dont have a problem with pushing a card to unrealistic settings as a part of the test but to draw any conlusions (or all in this case) on such a flaky test procedure is just plain wrong, its quite clear that the cards are not ment to play this game at such high settings and working the differance out of how poorly they performe on a % basis is... well worst than wrong, its misleading.
But when you spend this kind of cash on a "next gen" card you'll expect it to play crysis at 1680x1050+ though..
A pointless upgrade for GTX and ultra users then.
World in Conflict (1920x1200- 4X AA/16X AF)
8800gtx = 28fps
9800gtx = 23 fps
Lost Planet: XC (1920x1200- 4X AA/16X AF
ASUS EN9800GX2 = 59.40fps
nVidia 8800GT SLI = 54.70fps
nVidia 8800 Ultra = 44.80fps
nVidia 8800GTX- 768MB = 37.85fps
ASUS EAH3870 X2-1GB = 36.05fps
PoV GeForce 9800GTX = 28.35fps
LOL
Of course the GTX and Ultra are faster than a slightly clocked 8800 GTS 512mb, once you crank the res up and slap the AA/AF on, the GTS gets left behind as its got a smaller bus, its only a 256bit, GTX/Ultra are 384bit, this is nothing new, we saw it the first time around when these cards were released on December 11th, and Nvidia even stated the GTS would fall in below the GTX/Ultra, it was not replacing them.
Of course the GTX and Ultra are faster than a slightly clocked 8800 GTS 512mb, as you can see once you crank the res up and slap the AA/AF on, the GTS gets left behind as its got a smaller bus, its only a 256bit, GTX/Ultra are 384bit.
Ok then....
why it come last in the UT3 test even with no AA & no AF at 1650x1050
Unreal Tournament 3 (1680x1050- 0X AF)
ASUS EN9800GX2 199.70fps
ASUS EAH3870 X2-1GB 179.50fps
nVidia 8800 Ultra 178.60fps
nVidia 8800GTX- 768MB 156.70fps
nVidia 8800GT SLI 150.60fps
PoV GeForce 9800GTX 132.50fps
http://www.tbreak.com/reviews/article.php?cat=grfx&id=595&pagenumber=10
Crysis
1680x1050 results are off, 1680x1050 DX10 very high it should be higher than that for all cards.
