Just under two and a half years ago, I wanted a 4k gaming rig. The advice was clear... go big on the graphics card and budget on the cpu. Get a 2080ti (for a ludicrous price) and a ryzen 5 2600 (with it's 12 threads over 6 cores) and it would yield much better fps than a 1080ti and a more expensive cpu.
Which I did, and apart from the usual tweaks you have to do in pc games, I've been enjoying 4k gaming on my pc and big screen tv since. But now i'm upgrading my gfx to an nvidia 30 series and while i'm waiting for stock like most others, I've been wondering if my current cpu cuts the mustard.
Every review I see, in 4k results, the cpu makes very little difference. Like 1-2 fps even when comparing my lowly r5 2600 to the fastest cpus money can (theoretically) buy. Is this the reality or some oddity when it comes to recording fps? I keep hearing ubisoft games tend to need higher single core cpus but then the graphs aren't showing that in 4k. Something to do with the low fps being sent to the cpu from the gpu.
And also, it occurred to me I haven't changed the thermal paste in that time, is that a problem? I'm not noticing any issues but i'm not pushing the pc right now due to the temporary graphics card downgrade.
(as an aside, I also like how windows 7 is an option with the r5 2600, something i'd have to forgo if upgrading)
