if you want to whore points then medic all the way - you get 2 for a revive IIRC and 1 for someone using a medic bag that you drop.
as their head is literally central to my cross hair. the crosshair doesn't flash white as it usually would also.On a side note:
Does anyone else experience what I would call 'Ghost Shots'?
I.E. when in sniper class, you zoom in on an enemy's head pull the trigger, gun goes off, but nothing happens (most of the time when this happens I get killed whilst rifle reloads). It can't be lag as neither me or the enemy moves (both in prone position) and it's not just me being a poor aim eitheras their head is literally central to my cross hair. the crosshair doesn't flash white as it usually would also.
i was at a friends house this afternoon and he showed my 2142 (i play BF2 instead) and he says that if you yourself destroy both 3 core command consoles and the core, you get 1500 points.
The further they are the more the shot will drop down so you need to compensate the distance with a little hight over the target. It isnt as simple as point and shoot.
Then just pick them up off dead guys!(all I want is some new guns to play with!)
