Hi,
I'm considering picking up a 52mm circular polarising filter to accompany me on an upcoming beach holiday. I understand it will give me better results when shooting bright sand, water and skies...
Does anybody have experience of either the Jessops or the Hoya polarising filter? Which should I go for? They Hoya is more expensive, but is it worth it, and are there other brands I should be considering?
I only own one other filter, a cheap 'Bower' UV filter which was 'thrown in' when I bought my 35mm 1.8 in the States. Must say, other than the protective element against sea spray etc I was very dissapointed, as it often gave a 'ghosting' reflection between the two glass surfaces. Very noticeable when indoors under artificial lighting. As a result, I've simply not bothered with it.
Thanks,
Grant
Thanks,
Grant
But yes, go for the Hoya over the Jessops. I have a "cheap" Tiffen 58mm CPL and it is terrible compared to higher quality ones.
