Pollen Filter? (carisma)
Man of Honour
11 Mar 2004
ANyone have any idea how hard it is.where it is to change the Pollen Filter on a carisma?
I've got a workshop manual for it, but it doesn't appear to be under the a/c section.
Eventually found a cheap place to buy spare parts http://www.japarts.co.uk
although, still looking for spark plugs.
Hi Neil, try Bristol Motor Parts down in St. Philips right next to the tip.
Got all my Mondeo service items for £32 including pollen filter :)
If its the same as the Volvo S40(which it should be) as itsjust built on the same platform the you need to take the trim off under the passenger side dash. The filter is then found by removing a long clip and it should pull out.
