I'm pondering a suspension upgrade for my Fiesta ST and have settled on the following items...
Front strut brace (E-tech or OMP)
12.5mm rear track spacers (these move the wheel hub out 12.5mm a side)
Bilstein B8 Sprint Dampers
H&R 30mm lowering springs
I dont want to go really low nor do I plan to be tracking the car so I don't need the ride height or damper adjustment of coilovers, apart from which the cheaper coilover sets for the Mk6 Fiesta all seem to either be considered a bit too hard for road driving, or have issues regarding longevity.
I was wondering what sort of effect replacing the suspension bushes with Powerflex items or similar would have on ride/handling, and I know some of you lot have given your cars the full Powerflex treatment. Is it worth doing? And what difference will I notice?
