Polythene for killing weeds
17 Aug 2005
Swindon
Hi all,
Just recently got an allotment and we need to remove some weeds (which is most of the allotment!). Reading around black polythene seems to be the best option but I am unsure on what I should get.
Any advice on what to get and possibly where from?
Thanks!
1200 gauge sheets will do it, in black - clear sheets will be useless, lay it over and put a load of bricks to weigh it down. Will be pricey though especially if you need a lot and will take a long time.
Another option is weed membrane, it's more like fabric but its meant to have a mulch down on top and you plant through cut holes. Not sure how well that would work in an allotment.
Yet another option is glyphosate, I realise it would be used on ground to grow vegetables but it is neutralised when it comes in to contact with soil and after a few weeks the ground is safe again. If you did this though check the pack to see what the manufacturer recommends.
Get you fork and shovel and get digging it is the best way pick out and bucket the weeds as you go. A weed free allotment is hard work and will need regular attention black plastic and chemicals are useless once you start planting so get used to working the ground. It will get you outside, fit and ready for the real hard work in the spring there really are very few easy options on allotments!
Sorry to hijack this thread a bit but i'm trying to figure out some weed control for the borders of my garden.
They aren't large borders but i've hand weeded them about 4 times and new weeds come back in force. I think i was doing my original weeding wrong however as I was digging up the soil quite a bit when getting rid of the weeds which i've read can just unearth new weed seeds and they grow.
Would using some of this glysophate be the best treatment or would a combination of glysophate and covering with cardboard or membrane be the best way to go to ensure the weeds get a thorough bashing?
Chemicals will work once but the weeds will come back and strong weed killers will kill your plants too! You best bet to keep weeds down in a boarder and look nice is matting and a mulch which you can then plant through.
If you just want rid of weeds then concrete or astro turf are your friends
There arent any plants in them atm and I do want to plant in them eventually. I think a strong dose of weed killer then laying down some membrane should do the trick. What is a mulch? Is that just compost or is it a specific type of compost/soil? Could I just lay down several bags of multipurpose over the membrane?
a mulch is something you spread round plants and can be over a membrane (most membranes need it to be weed proof) normal things to use are shredded bark, manure or compost.
If its an allotment looks aren't important so get some old carpet it won't blow away in the wind either. Ask at the local tip. :)
Check the site rules a lot have banned carpet because it's an eyesore and people leave it to rot, I used carpets on my allotment and they were great as long as you remembered to chuck them every couple of years as they slowly disintegrated. Free cycle is another good place to pick them up and where I got all mine from.
Surely I dont want something that is damp proof?! But something that is semi permeable?
Correct - some say black plastic for long periods of time is bad for the soil. I use proper weed fabric for this reason on the beds of my allotment, and ordinary black plastic on pathways etc under a mulch.
