Poor Contact Or A Ok?
Caporegime
12 Jul 2007
United Kingdom
Does this look like poor contact between my noctua and cpu?
I'd be interested to know what other people are getting using this cooler Noctua NH-U12P SE2. I thought my temps were fairly low, then i saw someone else with the same cooler running 10c+ lower temps that prompted me to check the contact and i found that most of the paste was being pushed to the side.
I took the side off the case and felt the heatsink during load and it was getting warm. But i can't help feeling i could be getting better performance from this cooler.
as said already there, is not enough imo.
personally i use a rice size amount with a dot each side. so it resembles a +
push the cooler down and then give it a twist of about 45 degrees and back again. (this helps spread the paste)
secure cooler (never lift cooler, once you pushed it down, as it will introduce air bubbles)
Apparently spreading the TIM over the CPU before hand can lead to there being air bubbles trapped between the CPU and HSF.
I just checked arctic silvers site and they suggested a thin vertical line for an i5. I think the pea method works best though, maybe i just need to add a touch more paste when i reseat tomorrow.
