poor pings on o2
14 Oct 2003
South Derbyshire
Anyone else getting poor pings on o2 or any other isp to servers in London like Jolt.co.uk and Multiplay.co.uk ?
No I'm on interleave, usualy my ping is arround 19ms in dos, I have checked the interleave depth and that has not changed at all.
Tracing route to core1.multiplay.co.uk [85.236.96.22]
over a maximum of 30 hops:
1 <1 ms <1 ms <1 ms *************
2 * * * Request timed out.
3 * 88 ms 85 ms 10.1.2.173
4 23 ms 23 ms 23 ms 195.66.226.224
5 23 ms 23 ms 23 ms po0-1-650-cr1.ixnlon.as35028.net [85.236.110.6]
6 83 ms 77 ms 72 ms www1.multiplay.co.uk [85.236.96.22]
I just pinged my gateway IP and getting a steady 19ms.. must be some kind of peering issue.
anyone make any use of this trace..
Yeah ive noticed a bit of lag/packet loss on wow tonight. Its usually fine but seems a little jumpy.
Code:
Pinging core1.multiplay.co.uk [85.236.96.22] with 32 bytes of data:
Reply from 85.236.96.22: bytes=32 time=15ms TTL=122
Ping statistics for 85.236.96.22:
    Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
    Minimum = 15ms, Maximum = 15ms, Average = 15ms
Not on fastpath as far as I know.
Reply from 85.236.96.22: bytes=32 time=6ms TTL=122
Reply from 85.236.96.22: bytes=32 time=5ms TTL=122
On Be. Are you on O2's non LLU service O2 Access?
All has gone back to normal for me now steady 20ms
I'm on o2 LLU, thats an awsome ping there mate, but I spose you live next door to the servers ;)
