- 2 Aug 2012
- Leeds
I have searched for an answer to my problem, but had no luck. If anyone knows of a thread i have missed, please point me in the right direction
My problem:
A friend of mine is having trouble with her internet connection:
- her bedroom is on the third floor (attic conversion, if that makes any difference?) and the wireless router (virgin superhub, 60mb broadband) is on the ground floor on the other side of the house.
- due to the distance she cannot connect to the wireless network at all; the laptop simply doesn't find the network.
- she invested in a set of powerline adapters thinking it would be the answer, (http://www.overclockers.co.uk/showproduct.php?prodid=NW-032-TP) but even with the powerline adapters the internet speed she recieves is PAINFULLY slow. (<1mb download)
- Using the TP link software utility i can see that the connection between the two powerline adapters is 22mb (i THINK it's mb, not MB).
- running BBC speed test she gets less than 1mb download speed.
I am almost certain that this is due to the distance between the router and her room, because when i connect the second adapter in the same room as the router (socket a below) or on the other side of the house on the ground floor (socket b below), the signal is fine and the internet is fast.
It is very impractical to run an Ethernet cable from the router to her room, although i know that it would be ideal.
What can you genuises suggest to solve our problem?
(also, there are no mains sockets on the 1st floor that she could use)
this is the floor plan of the ground floor:
I have 3 ideas, although all require some loooong cables and would be a pain to implement:
1. run a mains extension lead from socket b to her room, with the powerline adapter plugged in at the end, with the laptop plugged into it.
2. plug powerline adapter in to socket b, with a long ethernet cable running from it to her room and her laptop.
3. the same as 1. or 2. but leading to the middle floor, where the powerline adapter is plugged in with a short ethernet cable to a spare linksys wireless router (wrt54g) i have, so she can connect to the internet wirelessly, but only through 1 floor.
comments and advise please!
My problem:
