Hi Peeps!
I have noticed that quite often when I download a uTube clip the quality is really poor and blocky
It is strange that this is not the case for all clips.
Even if the original tube clip is good quality in full screen, when I capture the clip it is blocky. (As you get with bad compression) This does not seem to be about the compression however, as the quality is still poor in the native .flv format.
I have tried both the free YouTube Downloader applicaion "http://youtubedownload.altervista.org/" and Tunebite both do the same. I have also run this on multiple PCs to rule out codec issues.
If anyone wants to play here is one such clip.
I captured the above using the YouTube Downloader
Below is a screenshot from the stream Playing directly from the captured .flv file. As you can see blocky
http://img35.imageshack.us/img35/1300/1234xql.jpg
Any ideas?
Cheers
It is strange that this is not the case for all clips.Even if the original tube clip is good quality in full screen, when I capture the clip it is blocky. (As you get with bad compression) This does not seem to be about the compression however, as the quality is still poor in the native .flv format.
Any ideas?
Cheers
