Poor signal Sky black wifi router - replacement?
1 Dec 2006
Amsterdam, NL
I'm looking at getting a replacement for the sky router. The black one.
Main thing is the WiFi signal strength. I'm at the limits with the sky one and need something that is outputting a much beefier signal.
Get you router and password from it. I use a Billion 7800DXL. dual band wifi, great coverage round my house, can't fault it. Picked it up 2nd hand for £70.
Sky will usually give you a free wifi signal extender if you ask, also before spending money consider where you can't get a signal and look at the reasons why.
