Hi all,
I installed the Zalman VF900 on my X1900XT (Not OC'ed) yesterday.
My Idle temp is 47 degrees. However when I run the performance test in Company of Heroes twice it is shooting up to 104 Degrees. This seems awfuly high.
I am running the latest Cat's with the CCC. I also have ATITool running to monitor the temps.
When installing the VF900 I used Articlean 1 + 2, and then I put a grain of rice sized blob on the GPU (AS5).
Should I try again as the temps seem why to high at load???
Also is there anything special I need to do with the fan control on ATITool. I have the fan mate attached to the VF900 and its set to high.
any help much appreciated
