Hi All,
Reaching out for some help here as I am at a loss (most likely based on my massive lack of understanding on this topic).
I have Virgin Media at home. A while back we had an extension built and as part of that we moved the router to the middle of the house (via cables installed by the construction team).
Previously:
Wifi:
This allowed the wifi to be reasonable across the house as it sat mostly in the middle of the house.
Direct connection:
As part of the extension we put in a box (not sure on name), where I was able to run cat5 cables from the router into the box which distributed it across the house to permament fixters (PC, TV, Console etc).
Life was good and covid19 wasnt here at the time!
Currently:
The main incoming cable from outside broker somewhere under the house. The route has now been moved to the front room and front corner (it couldn't be further away from everything in the house).
Direct Connection:
Fortunately the wires to the afore mentioned 'box' go both ways so I've been able to run a single cat5 back to it and am able to distribute to a few of my other permament connections. As the route is now by the main TV I've also been able to cat5 that aswell. So..... no losses on my permament connections.
Wifi:
This is where it's gone horribly wrong.
The box is just to far from anythign in the house to allow signal. The only place it really works is the main bedroom which is directly above the route.
I bought:
NETGEAR Wi-Fi Mesh Range Extender EX6250 - Coverage Up to 1500 sq ft and 25 Devices with AC1750 Dual Band Wireless Signal Booster and Repeater (Up to 1750 Mbps Speed) + Mesh Smart Roaming
But this seems to cause problems with my wireless printer and sonos. I think they both sit on the main router but when on wifi the other devices cant find them though I do not think it should work that way.
Here is an image that may help explain the above. I think I may have been generous with the wifi coverage.
Red is main line in. As you can see its gone from the middle of the house to the front.
The Right image shows a cat5 connection going from the front of the house to the middle to my 'box' and then out from there again
upload large pictures
How do I fix this?
Do I buy a proper wifi route and put it at the old 'box'?
Please note that under the current system I can't move the old box back to the original position as the main cable broke.
I guess I could buy a cat5 to cat5 connector??
Previously:
Wifi:
Direct connection:
Currently:
Direct Connection:
Wifi:
I bought:
How do I fix this?
