- 2 Jul 2007
- Nottingham
Currently the owner of a Gigabyte X800 graphics card which I've had for a couple of years. Over the last week after having my PC switched on for 10/15mins, my screen becomes covered with columns of white vertical lines then my goes into sleep mode, I've borrowed a PCI-E card from friend to confirm it's the card at fault (it is). Is there anyway of repairing the card (I'm fairly confident there isn't) or do I just need to chuck it in the bin?
Thanks
Thanks
