Just got back and turned my PC on. Took a couple of seconds longer before the POST check dialogue usually pops up and then it makes a horrible noise - a pop fizzle crack noise.
I quickly jumped at the wall socket and turned it off just after the noise seemed to have subsided.
Moment of panic.
No obvious smoke or burning smells coming from the machine so I took the side panel off, there is a noticeable smell inside the machine, a sort of burning plastic smell.
At first the seemed to be coming from around the CPU area but now its aired for a few minutes it only seems to be lingering around the PSU.
Now, what should I do? lol
I would obviously like to avoid causing any further damage so dont want to just turn it on again.
Assuming it is the power supply should I just trade it out and give that ago?
Im going to strip it down and look for any burn/scorch/oxidised marks.
Moment of panic.
