Pop Up Menus....
2 Oct 2004
N.W London
Hi,
My head hurts, please help...
Basically I wish to add pop up menus to each header in the link...
As you can see I have got the hovering part working but now need to add vertical pop ups around 5 links for each button...
here it is
Can someone kindly help? Plssssssssssssss show me the error of my ways
Thanks in advance..
I don't know what software you used to generate that ... but javascript rollovers are a bit old-hat.
There was some guy on a while ago who had a sliding menu system (java based( but very nice.
Otherwise look at Suckerfish menus.
There are software programs to render java menus, and submenus, if you really like that type of system. Could save you a lot of bother in the long run.
well im not really bothered what I use blade, as long as it works, been on this for hours, I have the rollover images for the first page, now just need to somehow incorporate a drop down menu into the nav bar...
dont know how tho?
all help would be most appreciated...
as i said as long as it works im not bothered what i use...
thanks
The answer is to use a pre-written javascript menu, such as Milonic:
http://www.milonic.com/
Which means dumping the Macromedia created imageovers...unless you really want to write the whole thing yourself in javascript...from scratch (which I'm guessing is something you want to avoid).
using a wide range of links ive tried so many diff vertical drop down menus its beginning to be a real pain, as I havent got anywhere
thanks
You either use something pre-written or write one yourself.
If you're not prepared or able to do the latter then you'll have to compromise.
