Popping audio from my PC - Different audio devices makes no difference
5 Jan 2004
Here is an interesting one, I am currently having some issues with the audio output from my PC. I was originally taking optical out into an external DAC and was getting popping and stuttering sounds.
I thought it was my DAC so I swapped this out for another one I had spare in another room and it does exactly the same thing. Then I swapped the optical cable for a USB cable which means my DAC is now basically the sound card and I am having exactly the same issue.
Anyone got any ideas what this could be? I imagine it is something to do with my power supply or motherboard?
I tried all sorts of sound messing, bios changes and Windows changes didn't really help.
I just rebuilt my PC, installed a new beefy power supply. Flattened my bios and re-installed Windows and all the drivers.
Seems to be all good now.
