Many people who have replaced their exhaust system with louder, lower backpressure pipes, have experienced an increase in the rapid popping/gurgling noises when throttling back and gearing down. With less backpressure, the exhaust vapors tend to load up in the system, and ignition of these vapors is sporadic and annoying. This popping occurs further down in the pipes, and is louder because of more open baffles, or no baffles at all. The quick fix for this is to simply "plug up" the air tubes that go into the cylinder walls, thereby preventing the air from getting there in the first place, thus, no "in-the-pipe" ignition. You may still experience some occasional popping, set off by the intense heat, but it is much less frequent.
