resistors? I would have thought capacitors... Not sure if it will stop the popping though.Cyber-Mav said:resistors
I suppose you could, I'm not sure how well a resistor would work though, I've always used capacitors for smoothing.Triad2000 said:I thought capacitors charge up with power and releases it slowly. In which case, resistors should be right?
