popups in xhtml strict
Markup should only ever be concerned with document structure, not behaviour, which is why there's no way to create a popup with a strict doctype.
If you want to manipulate behaviour, make use of javascript - preferably unobtrusively (Don't use inline javascript, assign all event handling through an external script, allow the 'event' to work if the user doesn't have javascript enabled).
iCraig said:
Will most client side popup blockers stop this feature anyway?
Which method? Mine?
If you were referring to mine, i've never come across a case where the popups have been blocked (using FF and IE popup blockers)...
Depends on the method behind the popup and the design of the blocker.
User initiated popups [clicking on a link] will, and should, be allowed through, while popups automatically spawned by a script should be blocked as they're the genuine annoyance.
