its a 1983 porsche 928s. 4.7, 16v, kjet, V8. 310bhp with 5 speed manual in black.
it has been sat up for over 15 years when there was a suspect head gasket failure.
to get it back on the road a lot of work is needed. There are a number of big steps and then a mountain of trivial things.
First trivial job was a compression test, I wanted to see if there was an obvious head gasket failure.
4: 11.9BAR 172.6psi ____8: 12BAR 174psi
3: 12.7BAR 184.2psi ____7: 11.9BAR 172.6
2: 13BAR 188.5psi _____6: 11.85BAR 171.8psi
1: 13.3BAR 192.9psi____5: 12.5BAR 181.3psi
bank 5-8 seems fine, im happy with that. bank 1-4 seems odd. cyls 1+2 are high. its only a 10:1 compression engine
First biggie is a cambelt change. I suppose it’s a good way to get introduced. That’s all good so far, just waiting for parts to come in the post (belt, tensioner, idler etc) c.£200. eeek
Ive had a play with the rad, found out that the integrated oil cooler is leaking into the rad (so lessening the chance of the head gasket failure)
Next bit step is the fuel injection. The kjet metering flap is seized, the injectors will be messed up too, so more work needed there.
Then I need to sort a radiator. Porsche want £900+ for a new one. Im going to get a large alloy item and mock up my own separate oil cooler with a big elec fan to replace the viscous one. A new stat is in the post too.
That should have the engine startable.
Then I need to replace gearbox oil, diff oil, brake fluid, brake lines, all discs and pads, pas fluid.
It ought to be road worthy then. Ill need to tax and MOT it and stick new tyres on.
Im aiming to do one big expense per month, so it may take a while. Not really counting the cost, things like vac hoses, plugs, HT stuff etc are all needed and I cannot be arsed adding it up (you never add up car stuff)
Oh, and then the kjet will need to be set up by a clubgti hero called toyotec.
And I need new fuel lines
May the force be with me etc
