- 2 Dec 2006
Ok so I've basically never managed to forward any ports over multiple routers now and I really need your help!
Internet - Virgin Media
Virgin stupid hub is set to modem mode
Router - Linksy E2000 connected via ethernet
Ip of the pc has been made static and I'm port forwarding to that ip address yet every single port on my pc seems to be closed when using online programs to check. Suggestions? What is odd is that I could still host a terraria server over hamachi.
When I'm port forwarding I'm using the same external port as internal port, is this incorrect? I've also used UDP, TCP and "Both" and that hasn't changed anything.
UPnP is also turned on. SPI Firewall Protection is enabled but didn't seem to work either when turned off and I've set a DMZ and that didn't help, don't even know what it does but I did it anyway haha.
Windows firewall is disabled also and all I have is AVG free, which I also tried disabling.
