Port Forwarding Not Working
1 May 2021
I have been trying to port forward on my windows ten laptop but whenever i check the port online it says it is closed.
i logged into the router management page and portforwarded port 27272.
I have tried disabling firewall and and antivirus but to no avail.
Im on a BT Home Hub 3 with a wifi speed of around 1.5mbps if that helps?
Any ideas or help would be greatly appreciated.
Do you see your device on the dropdown picker when setting up the rule or have you set a static IP?
