Port fowarding with skybb router for Torrent
  • Thread starter Thread starter 4p
  • Start date Start date
4p
4p
20 Jun 2006
Capital of The North
How the god damn hell do you do this
Ive opened and opened SO many ports used by torrent
Ive used portfowarding.com so many times aswell, was not to succeed.
I open the desired ports then do the test and it ALWAYS says those ports are closed
Wtf is wrong with this router
Maybe it's your firewall on the PC. Maybe your opening the wrong ports. Maybe not your forwarding the port to the correct IP address.
well you only need to open just the one port. just pick any random high number - anything between 10000 and 64000. might be worth checking to see if the router supports upnp. that way, your torrent app should be able to open the port it needs automatically. :)
i turned upnp off
turn it on? :p
