- 18 May 2010
Hi,
Can anyone recommend a portable battery please.
The Anker Pro 2 only puts out 1.5AMPS and the standard charger is 2.5 so I'm concerned it will be very slow so looking at alternatives but its seems unless you're American the options are very limited
Thanks
Thanks
