Portable monitor as second screen
18 Oct 2002
Stafford
I'm after a sanity check. I'm thinking of adding a Vissles-M as a second screen under my 34" Ultrawide LG.
I don't have space to the sides and space underneath is limited - the Vissles should fit.
I'm thinking of dropping monitoring / afterburner / FS2020 maps / displays / controls (it's touch screen) on it. Anyone done similar or is this a blinking stupid idea?
Al
Sounds very viable. However I use an old iPad for my second screen with a stand and that works for me. I use mine for Netflix etc.
I'm using Duet with my iPad pro and it works well as a second screen but the touch functionality is not that great, especially in FS2020 - this might be FS though.
Ahh you see what I wanted was just something to watch amazon prime and Netflix on but not be too big or generate more heat etc.
I found used tablets perfect especially the iPad Pro 12.9 screen and it’s also loud enough for my needs
