Portable storage solution for pictures?
3 Aug 2003
UK
I'm off on my Crimbo holiday next month and I'll be taking the little Ixus 400 with me but it only stores 14 pictures at full resolution on a full sized 32mb Compact flash card..
What would be my best purchase, to store a large amout of holiday snaps..
More CF cards with bigger memory or some sort of portable hard drive..
I was originally thinking of taking the Laptop but want to travel a little lighter than that. (dive gear is going to blow most of my Kg allowance as it is)
Cheers
Andy
Buy yourself a 1GB or 4GB card and you should have plenty of space for pictures. 1GB would give you over 400 pictures which should be more than enough.
1GB cards are only £20 on OCUK so you could buy a couple and have plenty of space for pictures.
Is a CF card a CF card no matter what it's size?
Just worried about compatability issues that's all.
Andy
It should be as CF is a standard, the point of a standard being anything that complies to the standard will work with anything else that does. So yes any type should be fine.
Not necessarily. CF comes in two flavours, Type 1 and Type 2. The interface is identical on both but the Type 2 is thicker and hence needs a Type 2 compatible slot. I'd guess the Ixus will be type 1 only.
Type 2 cards are pretty rare these days, they're limited to microdrives and high capacity cards, anything 2Gb and under should be type 1 these days.
