Portable Wifi hotspot on XP query.
30 Mar 2010
Under The Stairs!
I'm on holiday and one of my neighbours lets me use their wifi. The signal can just be picked up using a wireless n dongle in 1 only room of the house.
Is it possible to use the wireless n dongle(that needs to recieve the wifi signal) or the other inbuilt wireless g connection to create a wireless hotspot on my Dell mini 9 laptop running xp.
I would like to boost the signal so that I could connect my Xoom.
You should be able to either bridge the connections or set up ICS through the laptop.
Though this doesn't instantly turn it into an AP, a la infrastructure mode. Depending on the hardware and driver features you might only be able to create an ad hoc network from the builtin wifi.
