portrait duel monitors
12 Sep 2010
been doing some looking through the monitor section and it seems there is actually none with portrait stands? does anyone recommend any fairly cheap portrait monitors?
Dell Ultrasharp monitors tend to use stands that easily rotate to portrait, including these two:
http://www.overclockers.co.uk/showproduct.php?prodid=MO-056-DE&groupid=17&catid=949&subcat=
http://www.overclockers.co.uk/showproduct.php?prodid=MO-055-DE&groupid=17&catid=1425&subcat=
I would personally go with the 23in one as it is bigger and only costs £10 more. Here is a review.
These monitors use IPS type panels, so compared to standar TN panel monitors they exhibit very good colour accuracy and wide viewing angles (which is rather important when using in portrait, since you need good vertical viewing angles - which TN panels are particularly poor at).
