Hi,
I have bought a Posiflex PD2200S (rs232 serial connection), it came with a power supply but not data cable (rs232 9 pin).
I have two questions regarding this device if anyone has knowledge is that;
1. what kind of rs232 9pin cable does it require, a normal rs232 or a null modem 9 pin rs232 cable?
2. there are two rs232 connection ports, the first one a rs232 (pass through) male and a second one rs232 (with power) female. what are the differences of these?
this is basically to connect up to a epos software which I have. any help regarding this would be much appreciated.
thank you.
thank you.
