ive found that, if your case isnt particularity well filtered at the front and you have more exzust than intake then dust will will get draw in around your 5.25 devices and through your card reader usb ports etc so personally i would go with having it as an intake
I think its manly down to personal preference. I like to go for neutral pressure. I have 3x120's in and 3x120's out.
Though i do think its better to go for positive pressure over negative. So i would use the scythe as an intake. Just make sure its on a fan controller.. 3000rpm=loud
