After asking and reading about anti-static precautions on Ocuk, I was aiming to ground myself on a radiator in my bedroom; and luckily, I don't receive all my components for my first build until tomorrow.
The strange thing is (and I've never had a problem before) is that when I walked to the window and back again to to my computer desk, I passed on an electrostatic discharge to my new case. Now I'm thinking that this may be a problem as I will ground myself on the radiator and have to walk back across the carpet tomorrow. Unfortunately, I also can't use another room. I know the chances of it happening again are minuscule, but I'm a little bit paranoid now (as if I wasn't already
). I've also been told that other people have had an occasional problem with this carpet
I'm thinking of using the power supply, when fitted in the case, to ground myself when dealing with components outside the case. I understand that I have to have the psu in the 'off position', and I'm assuming the mains plug that the psu is fitted to also has to be switched off??? Though I must admit I'm a little bit paranoid about the whole psu thing. Someone has given me an anti-static wrist strap, which I figured I might as well use when working in the case.
Any advice is greatly appreciated.
.I'm thinking of using the power supply, when fitted in the case, to ground myself when dealing with components outside the case. I understand that I have to have the psu in the 'off position', and I'm assuming the mains plug that the psu is fitted to also has to be switched off??? Though I must admit I'm a little bit paranoid about the whole psu thing. Someone has given me an anti-static wrist strap, which I figured I might as well use when working in the case.
