- 18 Feb 2006
Hello,
i am planning on getting a Arctic Cooler for my graphics card so i can do some overclocking.
my problem is the chipset cooler on my current board, MSI K8N Diamond is very close to the PCI-E slots and i think the Arctic Cooler may partially cover the chipset cooler.
at the moment the chipset is running at 35degree's which is ok i guess for an overclocked system. but if i want to overclock more will i have a problem due to the chipset temp and the fact i might not be able to get another cooler for the chipset?
i have a Vantec Copper Chipset Cooler than i am not using at the moment, will this be better than the stock Northbridge cooler on the K8N.?
i will add a picture if i can to show you what i mean if i havnt really made it that clear.
) - if you use an SLI pair (or probably a crossfire pair ) you can't use the Zalman backplate on one card, it fouls the fan on it's neighbour. Doesn't seem to cause an issue though.
