Possible Conroe Setup
13 Nov 2002
GX-047-CO Connect3D ATI Radeon X1900 XT 512MB GDDR3 AVIVO TV-Out/Dual DVI (PCI-Express) - Retail (3056) (GX-047-CO)
£199.95 £199.95
CP-128-IN Intel Core 2 DUO E6600 "LGA775 Conroe" 2.40GHz (1066FSB) - Retail (CP-128-IN)
£214.95 £214.95
CA-024-EN Enermax Liberty 620W ELT620AWT ATX2.2 Modular SLI Compliant PSU (CA-024-EN)
£84.95 £84.95
MY-013-GS G.Skill 2GB DDR2 HZ PC2-6400 (2x1GB) CAS4 Dual Channel Kit (F2-6400PHU2-2GBHZ) (MY-013-GS)
£147.95 £147.95
HS-003-SY Scythe Ninja Plus Heatpipe CPU Cooler (Socket 478, 754, 939, 940, LGA755) (HS-003-SY)
£26.95 £26.95
MB-062-GI Gigabyte GA_965P_DS4 (Socket 775) PCI-Express DDR2 Motherboard (MB-062-GI)
£109.95 £109.95
Subtotal £784.70
VAT £137.33
Total £922.03
Tempted to buy the above once i sell my current setup for £500 to a lad from work, reckon the above will be good ? i wasnt sure on the motherboard/ram/graphics card/cpu cooler so any replies would be great, if you can think of anything better from the parts i wasnt sure of then please say so, i dont wanna spend more than £950 as this is the absolute max! :D
Yeah, that looks like a pretty nice rig there, don't need to change anything really.
Just buy it soon cause IIRC the X1800XT is on special offer this week only...
Ok some things aint in stock so im gonna buy these parts now:
£199.95 £199.95 - as its on This Week Only
and
Creative Sound Blaster X-Fi Xtreme Music - OEM (SC-043-CL) - because i wouldnt mind a new sound card :)
will buy the rest when the E6600 is in stock, might aswell buy the above so i can still use them in my current setup before i sell it!
ok ordered them 2 components (graphics + sound), now i have time to decide on the rest so any replies would be great :). i would order the lot but the CPU is out of stock and i kind of want it all to arrive at the same time
anyone have comments on the components i will be ordering? as i said im not sure on the CPU/Motherboard/Memory so if there are better components out there plz say :P, the pc will be used for everything, high res gaming etc and lots of overclocking
nice setup that Core2 chip will overclock nicely
as for gfx i would have went with the Connect3D ATI Radeon X1800 XT 256MB GDDR3 AVIVO TV-Out/Dual DVI (PCI-Express) - Retail (GX-044-CO) at 153 incl VAT
well worth it.
when i do purchase it i may go for that Swiftech CPU waterblock and watercool it as my current system is watercooled and i may aswell carry on doing so, but i heard good things about that Scythe Ninja cooler
if the need for a slient machine outways the cost of a water cooling setup then go for it. otherwise the Ninja will work perfect
