As it stands my system runs a phenom II x4 955 at 3.8GHz with 1.45v. This is as far as i have been able to take it and maintain stability. Looking at the temperature reported by coretemp it peaks at 55 degrees when running LinX. This is the current layout of the case cooling. (there is a 140mm silentwings fan in the side panel blowing inwards over the gfx card, also got an 80mm fan blowing on the back of the board) TIM i believe was arctic silver 5. (but i'm not certain as the cooler was mounted over a year ago)
I realise the deepcool fan is not in the ideal location atm. The front intake and rear exhaust fans are the coolermaster originals, bottom intake is an akasa amber and the fan on the megahalems is a scythe s-flex. I am thinking that i could move the deepcool up and mount it to the other side of the megahalems in a push pull config.
Can this be made more efficient or is the only way forward to move on from air cooling to liquid. (been looking at custom loops and the H100) I would like to try and pull some more out of my phenom or at least run it a tad cooler.
