OK i've just received my new Asus A8N-E, upgrading from an Asus A8V board.
I removed the stock heatsink from the old board, cleaned off all the old thermal grease, then applied some new AS5 to my cpu (A64 3500+), plugged everything into the new mobo and booted up and re-installed windows.
However I had a few strange hangs initially (during boot up), and when I managed to get 3dMark 05 running it hung around 1 minute in. Temperatures in the bios reported the cpu as being at around 52C after I rebooted.
I'm not too keen on the AS5, so I think I might remove the HS, clean it and reseat it with AS2 which I find much easier to apply properly. If this doesn't solve the problem then I suspect it could be due to the voltage. From memory I had to run my cpu at 1.55V rather than 1.5V in my old board, even at stock voltage. So maybe I need to run it at this higher voltage here as well.. This morning when I cranked up to 1.55V it ran through 3dMark fine.
Any ideas?
Any ideas?
