I thought I had a duff memory module (Ocz FX1150) so I returned them and got a replacement set. Trouble is, I still have the same crashing problem. If I have both modules in and I play something like WOW, it invariably crashes within 5-10 minutes. But if I remove the second module from slot B1 it seems to run fine on only one stick. Any suggestions?
Mobo is an Asus P5N32-E SLI plus. Memory is 2x 1Gig OCZ FX1150 (pc9200) running at timings of 5-5-5-15 which it has been set at since I got the machine. This problem only surfaced a couple of weeks ago.
