Possible dumb question...
6mm is fine, but what are you drilling into? Rawplugs are normally for solid walls. Those are wood drill bits??
Plaster ceiling, got my drill, got my light, all ready to try and install it :)
The other drill bits were for metal and brick so i figured the wood one would (no pun intended) be best.
Whoa Ohh.. I don't think rawplugs are intended to be used on plasterboard, they will just pull straight out as they have nothing to compress against. You need the butterfly type with little wings/clasps..
Like this..
Or this..
There are others but is sounds you need plasterboard fasteners for hollow plasterboard unless you know for deffo it's solid behind
I used those spiral anchor jobs in plasterboard in the top photo for hanging my canvas prints. Worked an absolute treat.
You're way better off using the ones DampDog suggested. I just gutted a plasterboard house and there was tons of holes where raw plugs had been used. They literally fell out of the board.
On the other hand the spiral ones were stupidly strong.
Rawl plugs like the OP talks about held up my big glass shower door on my bath (put there by previous owner), well they did anyway until the entire thing fell off and nearly broke my foot. Luckily all it smashed was the toilet seat - I was very lucky and had no idea how crap the rawl plugs where.
My personal view is to use decent rawl plugs. I use the B&Q standard ones where are pretty good, but not as good as the ones Dampdog's post shows.
In my experience, the 'free' rawl plugs that come with things are absolutely awful and should not be used. I like to buy the rawlplugs that come with screws, so I am 100% sure I have the correct one :).
I don't like the metal ones, they are to strong and not enough load spreading. Ive had far more success with the plastic spreading ones(not the large thread ones). Painting ok, but heavier stuff, found the plastic ones don't rip out.
They really should stop including the usual tat, it would then force people to go out and buy the correct fitting for the job.
I've seen stuff come with miniature 1.5cm rawlplugs :( I'd rather use blu-tack :/
You can get plastic rawlplugs that have expanding lugs at the side, for light fittings they work OK
That light rated for wet areas?
Also, generally most light fittings will have at least one screw directly into the stud, this is what you want to aim for then 2 spring toggles.
