Long story which i will try to shrink.
Other week my pc stopped working on start up. Turned on and pc went dead after approx 20 secounds then 15 then 10 then 5.
I replace the psu with no success. (this was the oldest part of the computer)
I then started to dismantle the computer and it would start as muh as possible with the cpu power supply not plugged in.
I replaced the cpu with no success. (Returned this one) AMD fx 9590
I then phoned asus as the motherboard was a Asus Sabertooth 990FX R2.0 Socket AM3+ 8 Channel Audio ATX Motherboard.
They told me the board was faulty. Still under warranty so sent back and got a refund.
Now i decide if im getting a new motherboard might as well upgrade to an AM4 so i get a Asus Crosshair VI Hero AM4 motherboard a RYZEN cpu and some DDR4.
I plug everything in and turn it on and straight away i get told by the bios i have no cpu fan. This is fine i think as i'm using a Corsair H100i v2 and there for it won't register the pump as a fan i had pre brought the AM4 bracket so it would fit on the new cpu.
Then i'm being told the cpu is over heating and has gone up to 90 degrees. I've not got out of the bios yet.
This all brings me to belive the whole propblem i have is a faulty water pump on my Corsair H100i v2 and gone almost to the point of replacing every part on my pc for a bl**** pump?
The fans on the radiators are col an the pipes coming from the cpu are cold so must be the pump is not pumping?
