possible faulty gfx card
3 Jan 2003
http://homepage.ntlworld.com/c.j.humphreys/pics/
guys does this look like a GFX card problem? the problem is intermittent and when it does happen a reboot solves it.
also it only happens on cod2, fear, css, bf2.
Other games like pes5, cod, mohaa, far cry, doom3 play fine.
the gfx cards a sapphire x800xt had it just over 12 months!
cheers
Topher
forgot to mention it does more often if i minimize bf2, css etc and drop to the desktop.
Yes - have you overclocked because it looks like the core is understrain? if you have overclocked clock it down a bit, if you havent overclocked then you should see if an RMA is possible.
What temps does it run at? Cards rarely just break but I suppose it can happen, doesnt sound like good news unfortunately mate.
2006-01-28 17:00:03 Temperature: GPU: 76.3°C GPU environment: 50.0°C
2006-01-28 17:00:33 Temperature: GPU: 76.3°C GPU environment: 50.0°C
this was whilst playin BF2 for about 45mins, used ATI Tool to check the temps
didn't have any problems whilst playing
