Possible faulty mobo? Can i draw your attention this way
10 Sep 2008
Macclesfield, U.K.
Ok, a fewdays ago it seamed like i was having probelms with a new build.
It looked like it was ram that took too many volts to power, so the guys on the boards helped me out, i sent it back and replaced it with suitable ram.
Now its looking like a faulty mobo, i get no signal to the monitors if pluged into the mobo OR the g'card.
Ive tryed it will all of the bits out individualy and still nothing.
Its the same spec as this http://www.overclockers.co.uk/showproduct.php?prodid=FS-180-OK
I bought all the same bits but upgraded the g'card to a 4850 512 xXx and the ram to Corsair XMS2 DHX 4GB (2x2GB) DDR2 PC2-6400C5 TwinX Dual Channel
I bought it in bits as i enjoy building and then insted of 1 year guarentee you get any where from a year to lifetime on the parts insted.
Please help.
Here is the tread if i can direct you here:
http://forums.overclockers.co.uk/showthread.php?t=18021007&page=4
Thanks for any help, i realy need it.:(
I've replied to your other thread.
Ideally the old thread needs moving back to here as the original title has turned out to be a bit of a misnomer (no fault of yours.). You could request it gets moved back with a new title. As it will save you from having to reply to suggestions that have already been applied.
Additional: You're not having much luck with this one - but you should find the problem with the components you can get your hands on
