Possible faulty Motherboard
10 Sep 2012
I have an ASRock Z68 Extreme3Gen3 that I had bought a while ago off of eBay.
Although at first the pins seemed to look okay, on closer inspection 2-3 pins stand out just a little, one of which look a little bent.
I've taken a look at the pinmap of the LGA 1155 socket and have figured that it's the SB_DQ[17] pin which is for the memory channel B.
The other 2 pins are VSS pins aka Ground Pins.
If I were to just use Memory Channel A would this be okay?
