Hi all,
First time posting on here so hello to everyone.
I bought the below setup in April of last year:
Gigabyte MA790X-UD4
4GB Vitesta DDR2 800MHz Dual Kit
AMD Phenom 9650 Quad 2.3ghz
1TB Samsung HD103UJ
Palit GTS250 1GB
Housed in Thermaltake Shark Case
Samsung 2032BW 20" monitor as primary, and an old 17" dell monitor as secondary
I'm also running Norton Corporate and SPF.
I had a few problems to start with, which seemed to be gfx related, but after installing newer drivers for the GTS it seemed to be ok. I also had issues with VLC crashing the PC, so opted for SMplayer instead.
Recently, however, I have begun to experience problems. A friend has lent me Fallout3 and to start with I was loving it. After a while though it began to freeze and crash to the desktop. I Googled this and found it was a common problem so I downloaded a patch for the game.
After loading the patch everything seemed fine for a week or so, but then the problem came back. Now though I can't even play the game, as it crashes back to desktop after about 5 minutes. I counted three times within 10 minutes the other day.
I also purchased the original left 4 dead and this seemed to run fine. I must have played it for about 2 and a half hours over the space of a couple of days and then the same problem developed. It crashed only the once, but then when I tried to play it again within 5 minutes it crashed back to desktop and continued to do so whenever I tried to play.
I had read about issues with SP2 and Directx9, so updated to SP3 (something i'd be meaning to do for quite a while). I tried left 4 dead again this afternoon and a similar problem is still experienced, although this time the game froze, both my monitors went into standby and the last sound that came out my speakers just looped over and over. I then had to reboot the PC because I couldn't get my monitors to come back to life.
This was the same issue I use to experience when using VLC, hence the switch to SMplayer.
Any help would be much appreciated, as i've had the setup for a little while now and know it is more than capable of running games like Fallout3 at a good res - left 4 dead should be no problem at all.
Cheers,
Dave.
Gigabyte MA790X-UD4
1TB Samsung HD103UJ
Palit GTS250 1GB
Cheers,
Dave.
