- 28 Oct 2004
- Somewhere, in a field in cheshire... alright!
Hello all,
What's happening is when I play any game and sometimes just using desktop the PC will shut off and restart. Sometimes in game it'll shut off as soon as the game has loaded or I can play the game for a few minutes before it goes off.
I've been having problems with the PC shutting off and restarting since earlier in the year but I thought it was down to the CPU overheating (heat sink and fan were clogged up). I had this R9 390 new in July which was maybe (not sure, can't remember) when the problems started but I just didn't think it'd be the card. What's strange is I've had phases where I've had no issues playing games.
I think I've established the CPU is not overheating, that usually reaches 70°C max and I've run windows memory check and that came back clear. Nothing is overclocked. I've tried my old 5870 and I played GTA5 (on lowest settings) for two hours without problem so it must be the 390.
I'm back using the 390 and I just downloaded GPU-Z and ran it while I played GTA5 and sure enough the PC switched off and restarted. It has created a log of events but I don't really understand it or know what I should be looking for.
Sorry this has become an essay but I've tried to explain exactly what's been happening. I'd very much appreciate any help you can offer. Thank you.
Iggy
Iggy
