Hi,
My brothers PC has recently started to crash about 5seconds to 5minutes into games. Sims 2, BF2142, GTR2, Just Cause the ATI tray tools spinning spaceship and even Armadillo Run.
The crash involves the monitor going black, sometimes the sound freezes, and it sounds as if the monitor is changing resolution several times. It continues constantly until restarted.
The PC is stable on desktop for a long period of time, not noticed any crashes. Only when something involving graphics does a crash occur.
Temperatures aren't high either and fan speeds are at max.
The spec is:
AMD 3200XP Barton
Asus A78NX-E Deluxe mobo
2x512 PC3200 Generic
ATI Radeon X800XT PE
He has recently gone to 7.3 drivers, then to 7.1 to see if that solved it, but still same problem. He hasn't tried any older drivers.
Thanks.
The spec is:
AMD 3200XP Barton
Thanks.
