Possible HDD failure?
sen
sen
23 Jun 2007
Recently I have been having some issues with my computer running rather slowly. After attempting to transfer some files from a CD onto my HDD the computer crashed, so I restarted and then a blue screen appeared stating something along the lines of 'Windows has encountered an error and needs to restart'.
After booting up again I received a message saying 'One of your drives needs to be checked for consistency'. Windows tried to fix the problem but kept saying something like 'There is not enough space to recover the orphan files'. Most were .lnk files if that means anything? When Windows finally loaded half of the icons on the desktop were missing although I hadn't lost any files/folders.
Other than missing desktop files it seemed to be running fine but when I turned the PC on again it wouldn't boot up, even in safe mode. I reformatted the HDD and reinstalled windows and now when you turn it on it takes ages to boot up and while booting up there is a sort of progress bar at the bottom that takes a while to complete...
Any ideas because I am stumped?
Cheers.
Need the specs of your computer. However, I don't think it's a hardware problem, I've seen that exact series of errors when a nearly full drive (with lots of small files on it) got corrupted, and I managed to recover the disk eventually. So you re-installed Windows and now have another issue - I don't believe the install has gone well, so if you can spare the time I suggest you delete the partition completely and let the Windows install create a new one for you when it re-installs. While you're at it, re-seat all drive and power cables in case there is a poor connection.
The HDD was/is nowhere near full.
Specs are as follows:
Athlon 64 3700
Asus A8N32 SLI Deluxe
2GB Corsair DDR
500GB Samsung Spinpoint
Geforce 8800GTS
Give hd tune a go and see what speeds you get.
Corrupt files and slow loading sounds like the start of a hard drive going bad to me but i may be wrong.
Best to make sure everything is backed up just in case.
