Possible idle control valve issue?
11 Oct 2011
UK
Hi,
My brother has a 58 plate Audi S3 and only recently it has started not to idle smoothly, it is as if you keep gently pressing the accelerator and releasing it and the revs keep going up and down slightly on there own.
This does not happen when driving, only when idling
Am I right in saying this might be the Idle Control Valve just needing to be cleaned?
Is this an easy thing to access and clean? Or best taking it to a mechanic?
Doesn't have an idle control valve. The throttlebody controls the idle, so have a look to make sure it's clean, it shouldn't be dirty on a car of this vintage. Could be a vacuum leak. For a car this recent, I would probably take it to Audi in all honesty.
Ahh okay, I assumed all cars had an idle control valve
I think he'll probably get it looked at by audi or a mechanic then. It is going to Audi to get serviced soon anyway in a couple of weeks
Shouldn't do any harm driving it like this until then, right?
