Possible in Wordpress?
11 Oct 2005
I know some folk on here use Wordpress as a CMS and it's something I want to try out. However I need to know if I'm going to be able to do the following...
1. Events List - what I'm looking for is something that will initially just show a list of upcoming events in a side bar, simply as something like:
"29th Aug - Open Mic Night"
"2nd Sept - Games Night"
Then the user can click on the link and be taken to a page that has full details about the event. Ideally I'd like to be able to log in, stick in the details for the event, and Wordpress would automatically display the events in order depending on when the event takes place.
Alternatively it might be ok to have an actual calendar image displayed, with any dates containing an event being in bold, and if you hover over that date, the event title is displayed - then if you click the date, you get taken to the full event details page.
Are either of these possible (or even a combination of the 2), and if so what plug-ins would you recommend to achieve this?
2. News items - want to be able to insert a page of news, and have a truncated version of this story appear on another page, alongside 4 other recent news items. The user then clicks for more info and gets the full article. The page with the truncated versions would display news from different sections on the same page. e.g:
GENERAL NEWS:
Snippet one
Snippet two
Snippet three
etc.
SPORTS NEWS:
Snippet one
Snippet two
etc.
Is this easy enough to do?
Help and advice would be appreciated, cheers.
Yeah it's definitely possible. Wordpress is very moddable... it may take some perseverance to get it exactly how your want it, but i've seen it done!
Using Wordpress as a CMS - good place to start is http://codex.wordpress.org/User:Lastnode/Wordpress_CMS
For point 1, are you getting these events from a database? If not, you can go to the widgets section of the worpdress admin and add a simple text widget (you can paste html into the box). If events change frequently you'd probably be best off with a database solution though.
As for point 2, I think you could create a say a parent category called 'News' and news categories as a child category to news.
Getting the news laid out how you want is definately possible via editing the template files yourself, but for speed there are a load of news based templates available: E.g. http://seo.redevolution.com/?wptheme=redevo_newsred or http://woothemes.com/demo/?t=41 (really like the whole woothemes series)
